Results 1 to 7 of 7
Thread: gas cap message
    Oct 2011
    24
    gas cap message
    Im trying to tune a 2011 Ram 1500 5.7L and the customer wants the "check gas cap message" off on the cluster. Is there anyway to tune this out?
    Taylor
    Nov 2014
    Moscow, Russia
    22
    Quote Originally Posted by gmtechnician View Post
    Taylor
    I suggest turning P0457 DTC off
    '03 Topkick C5500 LB7/A5
    '04 Silv cclb 2500HD LB7/A5
    '10 Ram ccsb 2500 6.7/A6
    Oct 2011
    24
    I did that and it's still on
    13,565
    Very possible it's a BCM function if it comes up in the cluster.
    May 2015
    1,908
    this
    Oct 2011
    24
    Yes but the bcm is getting its info from somewhere and I figured with the evap code gone the message should be gone too.
    May 2015
    1,908
    I believe BCM has a series of live monitoring that do not trip any codes and are purely used as a pre-cursor to the DTC final tests. Evap leak check only runs after a decently long interval of a full drive cycle, 24 hours sitting, then full drive cycle at a given ECT and mph range. BCM will on its own schedule check vacuum in the evap system. Not sure we have any control over that process in HP Tuners. You can completely disable the evap system if you want in the general settings, that may work.
