Results 1 to 8 of 8
Thread: RPM dives below 900
    RPM dives below 900
    I don’t know where to post this, this is not a tuning, I that’s something my car doing for really while. Now with HPT I hope to get this fixed.
    Right after I rev high it goes to idle and dives under 900rpm (approx 620) and jumps to 1100 and after idles normal. I have pic and .hpl attached
    frame 2752 and even deeper :4767
    www.turbofirebird.com tuned with HPT MPVI Pro, LC-1.
    Mar 2006
    7
    your timing does not look right to me, maybe smooth it out and see if it makes a diffrents.
    I did that , and also took few degrees to eliminate knock. the car works way better but still dives.
    Feb 2006
    Canada
    1,963
    I don't know a whole lot myself but the O2 readings look really low to me. Looks like a fueling issue(Guessing here!). I'm sure one of the seniors will nail this one for you............
    Advanced Tuner devildog9999's Avatar
    Feb 2005
    Niagara Falls, NY, USA
    354
    Does it occur during "normal" driving, or just when starting off in Reverse or Drive? Can you post up a scan with idle, cruise, and wot conditions? Make sure to log IAC's, Maff, Map, RPM, TPS, KR, Trans Current Gear, TCC, Speed, and LTFT. Also - does it happen when the vehicle is cold, or warm?
    Regal GS Site Owner / HPT Moderator / FTV6 Mod
    Look at your closed throttle timing in Drive. You are going as low as 10 degrees, this is allowing the rpm's to drop. Make your closed throttle timing 18 deg if you have a stock cam at that RPM and Grams/sec/cyl level.
    If you have a cam make it more.
    Mark
    Mark
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    I'd be allot more concerned with how lean at wot your at. The car is entering DFCO when in decel and shutting off the fuel. And yes, you need more low load/rpm spark timing.
    Russ Kemp
    Jul 2006
    1
    ok RPM dives below 900
