Results 1 to 8 of 8
Thread: 15 coyote whipple
    Jul 2009
    32
    15 coyote whipple
    I have a problem with a 15 mustang gt 5.0 coyote , he installed a Whipple supercharger with 10 psi , Bosch injectors also 58 lb / hr . Driving at low rpm is good, in WOT very good air-gas mixture , the problem is the constant speed between 2500 and 3000 rpm , the car moves up and down repeatedly acceleration, and I have some time invested and can not find the reason , I'd appreciate your help.
    Jul 2009
    32
    Tengo un problema con un Mustang GT 5.0 coyote 2015, que se instal? un supercargador Whipple con 10 psi , tambien inyectores bosch de 58 lb / hr . La conduccion a bajas revoluciones es buena , en WOT muy buena mezcla de aire-gas , el problema es a velocidad constante entre 2500 y 3000 rpm , el coche se mueve hacia arriba y hacia abajo varias veces la aceleracion, y tengo algo de tiempo invertido y no puede encontrar la razon , agradeceria su ayuda.
    Jul 2009
    32
    Somebody help me!!!!!!!
    13,565
    I know nothing on fords but if you really to help yourself here you need to post the tune and any log files of the problem.
    People need to see what the vehicle is doing and what you are seeing in the scanner.
    Nov 2009
    All Around
    3,149
    wrong section, i would post in the ford gas forum below
    you would also need to post your file and data log so we can help
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    If you want it moved just let me know where.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Jul 2009
    32
    here is the file, I appreciate your help.
    Jul 2009
    32
