On to the next problem...
So to fix the last problem I moved my VVE table values over to a mostly CTS-V tune (spark timing, VE zone boundaries, etc). This made the car run the best it has to date, especially considering there was no speed density tune done on this setup.
I configured this tune for speed density tuning and discovered right away there are some zones that need some major adjustment under this setup. The problem is I can't seem to make HP tuners generate reasonable Coefficients for the zones. It always ends up computing some bogus values.
Tune:
161 2016 Camaro SS LT4 - Speed Density.hpt
Before:
Delta needing applied:
After:
What's the best approach here. I've tried smoothing, etc., but the values will never seem to go where I need them to be. I know the zones can be redefined, but I'm unsure of the implications of this. Besides, I'm sure that will completely throw off the Prediction Coefficients and I have no idea how to get those adjusted properly from scratch.
Please advise. Thanks
