Results 1 to 3 of 3
Thread: LT4 Injectors and pump part #'s?
    Dec 2011
    Clovis, CA
    374
    As stated, anyone got the part numbers from the lt4 motor? My Silverado 5.3 whipple cammed 30% fuel lobes are driving the injectors well past 5.5ms to keep a/f stable. Im getting 6.5ms at 2250 psi with this setup. The injector size is still set as stock. I believe 96.4? Should I UP this value 30% to compensate for the lobes or no? Im a bit confused there. I figured the injectors and pump should fix this issue. I believe they are 140lb injectors...
    Helps greatly appreciated..
    Thanks,
    Dustin
    Mar 2010
    Texas Hill Country
    3,299
    Lobe data is in the fuel section rather than engine.
    May 2007
    314
    2003 MY Z06 3.3 liter whipple ...sold at around 1000 rwhp
    wip 2015 Silverado w/2.9 Whipple (phase 1 completed) phase 2 in the works
