Greetings All!
First post here. Sorry it is a bit long but the details might save people the time suggesting things we have tried.
I have got a client with a 2007 Tahoe 5.3. We just did a trans for him and thought I would see if I could get him the kind of performance gains we are seeing tuning the various 3rd, 4th, and 5th Gen 5.3, 6.0, and 6.2 GMs around here. Other than gutted cats the Tahoe is stock. From the beginning I saw unreasonable KR sporadically at idle and almost continuously driving steadily at 55. It was really lame to try to accelerate... I am guessing that the true octane of the gas here is about 90. I usually have to cut 1-2 degrees from the middle of stock LS1 tables but I can almost always get away with 7-9 more degrees on top. I know that somebody went through his motor a few years ago and I am guessing that they shaved way too much off the heads. I wondered if the cam control was just bouncing around but it does not set any codes....
Sooo of course I checked to see if it was lean but both the VE and MAF were quite rich. I gradually removed timing until it started to be able to function kinda normally. It took as much as 9 degrees at around 4800. I reluctantly removed some of the fuel in both VE and MAF knowing it would not help with the bigger issues. During one of the logs I watched the timing in Park as the rpm dropped from 1500 to idle. The timing was down around -5 for a few moments then low and behold more KR! Well at least I know that most of the KR I used to experience under load was removed with timing but this idle/no load KR is rediculous... Exhaust is not rubbing or banging on anything. New motor mounts. I attached the most recent tune and log. We will be so thankful if anybody can help get this figured.
Jeff
