I have a 16 hellcat in for pulley swap, long tubes, balancer, and cai. I received the computer back yesterday from the modification service and put it in. I cleared the codes as stated through the bi-directional controls. When I statred it the check engine light was on with no throttle control. So I shut it off and cleared the codes again with the bi-directional and the dtc menu and I clear all additives. Now I have throttle control but still have a check engine light with 9 DTC's for mostly throttle pedal and map sensor. P00FB, P0123, P012d, P0222, P1610, P1617, p2122, p2127, & u1424. SO I put the original PCM in and all is fine. Is this normal and I missed something or do I have a problem. If anyone has run into this and has advice I would appreciate it. Thanks
Rob
RTR Automotive
[email protected]
