What tables would I go after to increase the base airflow at idle. I'm just starting to get the fuel trims straightened out, but every time I come to a stop while driving to log trims, the idle drops down too low and it dies. I think the TB airflow at idle is to blame because of the increased displacement (from 5.7L to 6.4L).
It will sit there and idle, both in gear and in P/N once the idle stabilizes, but if you rev the engine above, say, 2500 rpm, it will die before the idle can catch it when it drops back to idle. If I let it down slowly with the throttle, it will idle nicely. Fuel trims are +/- 2% in these cells, so it's close. I just need to get this thing to idle so I can log fuel trims without it dying at every stop.
Thanks!
