You are seeing trims at WOT, nothing more. If the stoich value is 14.1 in the tune and the fuel in the tank is not E10 then yes, you will have trims. GM does this too, just not at WOT because they don't use widebands.
If GM shows a positive LTFT at part throttle then it too will carry over to WOT fueling and your actual lambda will be richer than commanded. No difference.
I disagree Politely of coarse.
On the Ford the trims are not carried over, they are a direct correction for the MAF error in real time.
You can then take that error and place it right on your MAF curve and get near Zero fuel trim correction the next pull.
I know the GM positive LTFT will carry over but I tune to negative 1-2 % so I don't have that problem
I didn't say ford trims carry over but the effect is the same. The only difference is the gm doesn't introduce negative trims at wot.
