Results 1 to 3 of 3
Thread: What does TSS stand for in RPM limit?
    Aug 2015
    230
    Could someone explain what the TSS axis is referring to and what these tables are used for?
    Jan 2013
    Hawaii
    2,101
    Turbo shaft speed. From this pressure ratio/ airflow chart I found of the gt3582r I would guess these would be used to limit RPM when a non boost state is commanded by the ECU.
    Oct 2011
    QLD, Australia
    436
    Rolls in this instance I believe it's Turbine shaft speed (specifically inside the torque converter)
    Ford BF Turbo Ute,Stock head/cams, In house built bottom end,Atomic Springs, Forged Rods,Cosworth Pistons,Atomic Billet oil pump gears,ARP Head/mainstuds,Process West Stage 3 Cooler Kit- Plazmaman plenum,Precision Int.Gate 6466,Manta twin 3" exhaust,ID1000s Plazmaman surge with Holley 12-1800 pump, Home Built ZF6H26, On United Pump E85 499rwkw 10.5@135mph https://www.youtube.com/watch?v=dgZupPhrMss
    Latest mods, FG intake manifold conversion and ID1300s-500rwkw, Yet to see the 1/4Mile
