Could someone explain what the TSS axis is referring to and what these tables are used for?
Turbo shaft speed. From this pressure ratio/ airflow chart I found of the gt3582r I would guess these would be used to limit RPM when a non boost state is commanded by the ECU.
Rolls in this instance I believe it's Turbine shaft speed (specifically inside the torque converter)
Ford BF Turbo Ute,Stock head/cams, In house built bottom end,Atomic Springs, Forged Rods,Cosworth Pistons,Atomic Billet oil pump gears,ARP Head/mainstuds,Process West Stage 3 Cooler Kit- Plazmaman plenum,Precision Int.Gate 6466,Manta twin 3" exhaust,ID1000s Plazmaman surge with Holley 12-1800 pump, Home Built ZF6H26, On United Pump E85 499rwkw 10.5@135mph https://www.youtube.com/watch?v=dgZupPhrMss
Latest mods, FG intake manifold conversion and ID1300s-500rwkw, Yet to see the 1/4Mile
