Many KR no stock config
Hello
I was doing some changes to my Camaro 2013 v6 manual and was seeing many KRs in my logs.
Some one could review my tuning file and help to improve that?
Logs:
http://mitsui.social/camarov62013/v3/log-kr.hpl
HPT File
http://mitsui.social/camarov62013/v3/vcm_maf.hpt
THAT'S A Lot of knock... And it is constant.... What kind of fuel are you using... Try running to empty and run two tanks of 93...and see if that stops the knock.. because there is NO reason you should be seeing that when you are only running 20-17 * of spark from .40-.52 Kpa at 1600 RPM...I'M running 27* to 23* (7 degrees higher) respectively in my Camaro at the same Cylinder (Spark) Airmass Kpa values without ANY KR.... There has to be something wrong with either the sensors, something is loose and triggering the sensor, or the motor really is knocking.. BADDLY!!... Either way something needs to be fixed...JMHO
