Probably a dumb question, but is there a way to force the vehicle to cruise at a leaner than stoichemetric AFR without doing a Speed Density tune?
I guess I'm wondering if MAF can somehow be less involved in cruise AFR?
2000 Trans AM WS6 6.0, 4L80e, 9"
2008 Silverado LT 5.3 liter Work Beater
I have the same exact question. Thank you for asking this!
I`m no expert but how about Lean Cruise mode?
1955 IH R102
Mustand 2, 4 link, Ridetech coil over air suspention, Dana 60 W/ True track.
LS1 4L60E.
Hot cam, ported 799 heads, fast LSx, 42lb injectors, 92mm TB and 11.1 CR.
O2 rich/lean vs airflow. I'm not sure how far you could get it to go, and I'm sure it would take a bit of trial and error, but I believe you could lean it out some. You should figure out which airflow mode you're in when cruising and just change those cells. I'm pretty sure there's several threads about it on here if you want to try searching.
1999 s10 blazer trailblazer edition nv3500 swap
2006 GMC ccsb 4x4 duramax/allison
Speed density itself won't do it if still running closed loop. You would have to run open loop or enable lean cruise with other tuners. You can't enable LC with HPT. Even with LC you don't gain much MPG without other tune changes to go along with it.
I had tried that a few years ago, and saw no change whatsoever. I was hoping there was another way found in the time it's been. I guess not.
Yeah, this is just for my truck, trying to gain a little more MPG...probably not worth the aggravation. Thanks for the replies.
I am new so I may be talking nonsense..
Why dont we change the O2 Rich/lean vs Airflow bank 1 and bank 2 tables to a lower voltage?Capture 4.JPG I may try this but I will have a WB hooked up soon. Do you think we can tune more fuel into it with the PE table for hard acceleration?
Changing the O2 switchpoint will pull your closed loop AFR.
I've played with this. Below about 300mV I started to see
a bit of surge in cruise control. I did not play with timing.
PE mode is open loop and a totally separate issue. If I were
you I'd tune for open loop stoich and then use closed loop
to put the steady stare mixture where you want it, on the
highway. As far as PE goes, factory tunes are over-fat to
begin with (I expect, so as not to pay a lot of warranty
on blown up motors). It's unlikely you want even as rich as
stock, let alone richer.
