Results 1 to 13 of 13
Thread: Correct method Centri blower with Methanol?
    Jun 2012
    Pirate Ship
    93
    What is the preferred method or more correct way with an Alky control kit on a 2015 C7 Corvette with a Procharger Kit? Targetting 0.86 lambda value running on E10 premium fuel. Better off pulling fuel from the Power Enrichment tables or pulling from the 6000+ Hz MAF table. The MAF method significantly lowers the g/s airflow, drops cylinder airmass and also lower torque calculations. (car is a M7). The PE method will leave the airflow values in tact, but then you commanded and actual will be off. Currently at 10 psi and 1.14 g/cyl airmass doing the MAF method.
    Aug 2009
    Calibrating
    3,373
    I've always adjusted my fueling with the maf...
    I would increase the fueling a little if it was me, especially at peak cylinder pressures (peak tq)
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jun 2012
    Pirate Ship
    93
    I am 1.160 in the PE table above 3000 RPM, which spits out a commanded of 12.15 in my scanner. I see others recommending 12.2-12.5 and I thought I was already being conservative. The fuel is 93 octane (E10) with 100% methanol out of a single nozzle Alky kit.
    Aug 2009
    Calibrating
    3,373
    Since you using actual e10 14.1 as you set point then this afr values are fine
    14 Gen 5 Viper
    Jun 2012
    Pirate Ship
    93
    Okay because I always calibrate my wideband to output lambda, found it much easier this way. So my commanded is 12.15 on the AFR scale, can I safely lean this up to what a few on here have suggested or would you recommend to leave it alone?
    Aug 2009
    Calibrating
    3,373
    Leave it alone... You would either pick up very little or non at all... Especially being on meth, I would leave it due to cylinders getting equal amounts of fuel... If you lean it out that just means some cylinders are getting hotter than others most likely
    14 Gen 5 Viper
    Jun 2012
    Pirate Ship
    93
    Any advice or point in the right direction to tune the VVE table? I already have the baro broken out of the harness and a customer PID for pressure ratio (MAP/baro). Is it as simple as failing the MAF like on the Gen III stuff? I am trying to do the VVE open loop
    Mar 2010
    Texas Hill Country
    3,299
    on a 15 you should be able to just fail the maf. on a 16 a failed maf won't let you get into boost.
    Jun 2012
    Pirate Ship
    93
    Quote Originally Posted by Higgs Boson View Post
    Excellent, anyone ever heard of generating GMVE from the corrected MAF to get a jump start on roughing in the VVE table?
    Also looks like it is back to the drawing board. I originally had the Alky gain on 6, but I checked the turn on point and it is coming on just past atmosphere (1.0-1.5 psi) so I need to dial it up to around 4.0-4.5 psi
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by Midnite Magic View Post
    yes many people use the MAF to tune the GMVE, I prefer lambda error but on 16 and up it's not an option so far over 1.2 or so PR.
    Tuner in Training NicD's Avatar
    Dec 2005
    phoenix, az
    40
    On manual cars you can do it either way but I prefer to keep the torque model correct and the MAF table correct and pull fuel out with the PE table for methanol. Yeah yeah pe doesn't match anymore since the methanol is extra fueling but it has the least impact doing it that way and things still match up so oh well. With autos I wouldn't even consider pulling it out of the MAF/VVE because of the torque model impact.
    2016 C7 Z06 | 2017 ZL1 | 2009 C6 Z06 | 1994 GT - The LS-stang | 2010 Tahoe SSV
    Jul 2016
    12
    I'm no tuning guru but am still learning. I tried it both ways and got better results with PE tables and leaving maf alone. I ended up at 1.04 on the PE tables for the most part. commanding 14.13 and my AFR is 12.1 at WOT steady all the way to redline. alky setting on 6 and coming on at 4psi.
    Jul 2016
    12
    running 17 degrees of timing with 8psi boost.. Zero knock so far
