Originally Posted by
06300CSRT8
FYI - the throttle body airflow table did absolutely nothing, all it did do was result in the Total Airflow PID in the log to increase or decrease and basically just display whatever I put in the table. Its clear total airflow is a calculated number, not actual airflow, and it simply shows whatever I input to the throttle body airflow table. I stressed it to an extreme putting in values of 50 g/sec in the idle voltages and got exactly those values in the log at the same voltages I once logged 8g/sec.
What did eventually work was INCREASING the airflow in the row axis of the large and small desired airflow tables. Makes zero sense, clearly these tables are entirely mis labeled and don't function at all as they are described. To me, these two tables are the ACTUAL throttle body airflow tables, not commanded airflow tables. When I increased the airflow value at 0.20 volts, next log it immediately closed the throttle body more at idle in gear and got rid of almost all the cruise control feeling.
