I made the needed change under speedo for the new gearing and the speedo is dead on and most things seem fine. All other tables are stock settings right now.
One thing I have noticed (going off the dash rpm's) is with the new gearing I run about 2400-2500rpm at 70mph. When I let off the throttle (0%) my rpm's slowly fall to about 2200rpm and then fall of instantly to about 1600rpm, fall slowly again to about 1300 and then instantly jump back up to about 1800rpm. It's a little annoying.
Is this because of the higher stall? And does the TCC table need adjusted or is this something I just have to live with? Any other table changes that should be considered with the new gearing and stall? Again I'm just running stock tables at the momment.
