Results 1 to 20 of 27
Thread: 2016 Camaro SS Rev Limit
    Apr 2014
    12
    We seem to be having some difficulty raising the rev limiter in neutral on this car no matter what it is set at the car will not rev over 5000 rpm with the clutch engaged. The rev limit once the car is moving seems to be fine, just trying to leave harder on the starting line and car will not rev past 5000.
    Jan 2012
    Carolina, PR
    43
    Did you verified Fuel Cutoff rpm vs gears?
    Apr 2014
    12
    Quote Originally Posted by Charlie540i View Post
    Yes all set to 6600.
    Mar 2010
    Texas Hill Country
    3,299
    post tune if you want help
    Apr 2014
    12
    Attached the tune file
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    Are you in launch mode when it does it?
    That data is in the BCM and not editable.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
    Apr 2014
    12
    Not in launch mode when it does it. It will not rev past 5000 unless the car is moving.
    Nov 2009
    All Around
    3,149
    there seems to be a table missing, like in the E38 PCM "wheel Speed Limit"
    see if changing the General Limiter from GMLAN to Calibration
    Apr 2014
    12
    I will give that a try.
    Quote Originally Posted by SultanHassanMasTuning View Post
    Apr 2014
    12
    No luck with that, we just had an auto car in today and rev limits work fine on it.
    Is there a table missing from the manual cars?
    Nov 2009
    All Around
    3,149
    request for wheel speed limit
    Jun 2019
    38
    Was this issue ever resolved??
    Aug 2009
    Calibrating
    3,373
    Keep foot off the clutch and should rev up!!
    Interesting enough I have a 17 auto trying to shift at 7500 RPMs and we have a phantom rev limiter coming in around 7200rpms.. I think I have a fix but just have to test it!!
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    May 2003
    South FL
    1,368
    I ran into this with a 2018 ZL1 1LE Manual car
    ENGINE > FUEL > CUTOFF,DFCO > RPM Limits > Misc > Commanded Torque
    RPM Limit Torque vs RPM vs Gear
    This table you would need to set Neutral to 6,042 (or another high number) or the car will never rev past about 5000 RPM in neutral. I believe that neutral counts for any gear if the clutch is depressed. But if it doesn't in your particular car you can set the whole table to max value and see if it gives you the desired result. If you're just trying to launch the car in 1st, try just 1st and neutral.
    My client wasn't able to throw "mean revs" at the competition during roll races and parking lots in Mexico. Something I've never thought of lol. But I found this table fixed the "issue".
    [email protected]
    Owner/GM Calibrator
    Aug 2016
    386
    Manual transmission cars have launch assist tables that come into play and in some cases cause an issue like this (I don't think these tables are in hpt). Does it rev limit to 5000 RPM if the vehicle is moving slowly, like 10 MPH?
    I'll try this tonight. Thank you!
    I have a buddy I'm working on tweaking a tune for and he can't launch (manual) as it bogs really bad out the hole on radials. Couldn't quite figure out why, but this table seems like a good option to test, so I'm upping the torque for 1st and Neutral. He has a 2-step and also complained about not being able to get revs above 4300rpms (he's H/C/I/E80) when his 2-step was set to 5200.
    Aug 2014
    Central, LA
    737
    This table is likely the fix for Ben's issue as well...
    Just tested this - WORKED LIKE A CHARM.
