Results 1 to 12 of 12
Thread: 2016 Camaro SS Rev Limit
    Apr 2014
    12
    We seem to be having some difficulty raising the rev limiter in neutral on this car no matter what it is set at the car will not rev over 5000 rpm with the clutch engaged. The rev limit once the car is moving seems to be fine, just trying to leave harder on the starting line and car will not rev past 5000.
    Jan 2012
    Carolina, PR
    35
    Did you verified Fuel Cutoff rpm vs gears?
    Apr 2014
    12
    Quote Originally Posted by Charlie540i View Post
    Yes all set to 6600.
    Mar 2010
    Texas Hill Country
    3,242
    post tune if you want help
    Apr 2014
    12
    Attached the tune file
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    437
    Are you in launch mode when it does it?
    That data is in the BCM and not editable.
    Owner: Crawford Racing LLC
    www.crawford-racing.com
    chris@crawford-racing.com
    Home of the CR-Fueler plug and play port injection controller for late model GM DI engines L83, L86. LT1 and LT4 applications
    Apr 2014
    12
    Not in launch mode when it does it. It will not rev past 5000 unless the car is moving.
    Nov 2009
    Jeddah, Saudi Arabia
    2,273
    there seems to be a table missing, like in the E38 PCM "wheel Speed Limit"
    see if changing the General Limiter from GMLAN to Calibration
    E-tuning/remote Tuning Sultan@mastuning.net Follow @MASTUNING Contact/Whatsapp +966555366161
    [URL="http://www.mastuningsaudi.com"]
    Apr 2014
    12
    I will give that a try.
    Quote Originally Posted by SultanHassanMasTuning View Post
    Apr 2014
    12
    No luck with that, we just had an auto car in today and rev limits work fine on it.
    Is there a table missing from the manual cars?
    Nov 2009
    2,273
    request for wheel speed limit
    Jun 2019
    3
    Was this issue ever resolved??
