Results 1 to 8 of 8
Thread: Anyone have the voltage formula for 3 bar GM map?
    Aug 2005
    335
    Just what the title says-thanks!
    GO RAIDERS!!!!!!!!!!
    02 C5 Z06
    8.8@160
    Houston, TX
    349
    0v = 0kpa, 5v=304kpa I believe
    2.4L Twin Cam Cavalier Z24 | T3 Super 60 @ 9 PSI | FMIC | TurboXS RFL | Greddy Profec B Spec II | Custom HO Intake Manifold | 2.5" Charge Pipes | 2.5" Downpipe | HP Tuners | 5 Speed Swap | Team Green LSD | SPEC Stage 3 Clutch | Fidanza Short Shifter | Prothane Control Arm Bushings | Carbon Fiber Hood
    Aug 2005
    335
    Dude-your car looks sweet
    02 C5 Z06
    8.8@160
    Apr 2003
    Almost 2000 feet.
    7,876
    Everything you never wanted to know about that sensor
    From PowerandSignal.com HERE
    Always Support Our Troops!
    Any way of taking that 5v signal and converting it to PSI? Id love to log boost
    Apr 2003
    Almost 2000 feet.
    7,876
    Quote Originally Posted by Rodimus_Prime
    Not a problem:
    315 Kpa/5vdc= ~63 Kpa/volt
    To get to PSI you multiply the Kpa by 0.1450377
    Max Boost is 31.1 lbs.
    EC
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    Quote Originally Posted by Shifted
    none of teh MAP sensors = 0kpa at 0 volts
    or atleast I havent seen one yet that did
    *usually* 0 volts
    1 bar = 10.33
    2 bar = 20.66
    3bar = 30.99
    and 5 volts
    1 bar = 94.34
    2bar = 200.00
    3 bar =304.00
    -Scott -
    Nov 2002
    Central Florida
    2,503
    They all have a spec floor at 0.25 or 0.5V and a max of
    4.5 to 4.85 in the datasheets I've seen. Here is one (.png)
