Has anyone played around with the wot cam timing on stock cam and picked up any power? If so can you give me an example or and Idea on where to start, thanks.
Just do some basic cam sweeps on a dyno. Change cam timing in small amounts and record the changes. You will have a sweet spot for making TQ at different RPMS. If you don't have access to a dyno you can use a "virtual dyno" to calculate power based on your vehicle and how quickly it accelerates.
i believe with the Hemis only exhaust cam timing will make an affect in the power band
Remote Tuning [email protected]
