RAM Reverse horn blow
At least some Dodge Ram pickups blow the horn and enable hazard lights if the truck is put into reverse with the door open. Is it possible to disable that "feature"?
The recall involved flashing the front control module and cluster so you wont be able to do anything with the HPT. You can however short the pins at the seat belt switch, the horn won't go off if the seat belt is "latched"
Ok, thank you.
Out of curiosity... was there a recall just to add that "feature" or was that work done as part of some other recall?
