can anyone tell me whats going on? I cant get my truck to run on sd 2 bar. I put ls3 injectors in it and may or may not have the data input correctly-kind of think I do. I loaded the 2 bar with the ls3 injector data it doesn't want to run, if I hold the throttle to the floor it will hit but smoke really bad like the injectors are hanging open it doesn't want to run at all. so I put the base tune in which is just the old tune with the 2 bar changed on it--this tune has the 23lb injector data in it--more of the same. but if I load the old maf tune in it it will run this tune has 23lb injector data in it. I did check the map sensor and with the 2 bar tune its reads 101kpa with the key on engine off, when I flash to the maf tune it reads 51kpa. don't know if the map is the issue or not.start up map2.hpt
