Results 1 to 3 of 3
Thread: Does the Scanner Support ABS DTC's
    I have an ABS and Stabiltrak light on on my Son's 2103 Malibu. I can see scan data from the engine, but the scan tool does not show any DTCs for the ABS system. Just wondering if HP tuners supports the ABS DTCs or I will have to go somewhere else for those codes.
    Thanks,
    Dec 2014
    592
    As far as I'm aware, the HPTuners scanner only supports ECM/TCM codes (no ABS, no BCM, no airbag, etc) - just ECM/TCM.
    Quote Originally Posted by jtrosky View Post
    I think that is right. I found someone with a hand held Bosch scanner and it did read the ABS codes, so HP Tuners must not have access to those codes.
    Thanks.
