G'day guys.
I've been working on getting my VE sorted in open loop and the car is running better all the time as i adjust, problem is when i switch over to closed loop it runs okay but would say it is 75% better in OL than CL.
I'd like to be able to run it 100% of the time in CL (if i can).
Specs are-
Cam @ .050 233/238 115lsa
Single i/cooled turbo, both O2 sensors about 30" from turbo dump (this is my CL issue i think)
DW 65lb injectors
No MAF fitted (SD only)
When running in CL I've notice from my logs it is nearly always tending to run leaner when at a constant rpm (plus a few other issues), I'm thinking that maybe the reason is my two O2 sensors have been moved from just after the old cast manifolds to now being about 30" from the turbo in the dump before cats (both in the same pipe side by side).
Can also feel surging which I'm thinking coincides with the rich/lean O2 swings.
So far i have tried (from research)-
1.Closed loop proportional airflow stock x 0.835
Closed loop integrator delay stock x 1.1
No change with above
2.Closed loop proportional airflow stock x 0.9
Closed loop integrator delay stock x 1.25
3.Min rich/lean from 250mv to 450mv
Max rich/lean from 650mv to 450mv
No change with above either (with same air and delay as 2above.)
I've tried reading everything i can but finding very little information with a similar setup as mine (turbo, dump and O2 sensors)
Thanks in advance, any help would be greatly appreciated.
Also, which tables do i need to adjust so as i can get a constant AFR commanded when tuning VE in open loop (it varied from 14.7), Open Loop EQ Ratio Gas gear/ P/N?
Attached is CL drive, OL drive and current tune.
