I was told if locking a triple disc circle D converter on wot shifts to avoid that dreaded time to lockup that the pwm values would need a minimum of 98 and a maximum value of 99. I went to the scanner and added the pwm channel. I have not hooked it up to the vehicle to scan, etc. When I do how do I enter values into the hp tuners system? This is when I am going wot and shift into third and fourth. The shift extension will go to 5200 and then it slips backwards to 4800 or so before it fully locks. Thanks
