On the SHO, I noticed that the wideband data shows I'm running rich at around 5500-6000+ RPM at WOT. Commanded lambda is 0.85 at WOT, and the actual lambda is 0.85 up until that region, which it then dips down to 0.78-0.79
I'm running about 17-18 psi
I looked at every table and made all of the changes (COT, min lambda, etc...) and changed it all to 0.85, but it still dips into 0.8-0.81
Is there a table missing? Fuel source still shows (OL) Power Enrichment during WOT testing, and no limiters are showing up. Other than a missing table or a setting I missed, does this seem like something that needs to be adjusted with speed density?
