Results 1 to 3 of 3
Thread: FID 1000CC injectors scaling
    Oct 2013
    Denham Springs, LA
    146
    Whats the quickest and easiest way to scale a tune for these injectors.
    Which tables under fuel should be looked at.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    If you're hitting the injector flow rate limit then double the stoich AFR table, cut the supplied injector flow rate table in half. Cut the IVT terms tables in half and you're done with the hard part.
    Also need to copy over the short pulse adder and offset tables from the data that was (hopefully) supplied.
    And that's pretty much it.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Old thread, but did FID supply data?
