Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Thread: Spark limit testing
    Spark limit testing
    guys,
    I have added new parameters to the following calibrations:
    12221098
    12221096
    9382927
    9382928
    9382957
    12206042
    12206017
    9382938
    9382941
    12206019
    12206035
    12222128
    12583655
    12578485
    12583711
    12216489
    12584719
    12586586
    Please download the latest 2.1.11 beta and install (email support or PM a mod if you don't have the URL). I emailed everyone who emailed me files.
    The new params are on the Spark Advance form. They control the RPM and VSS that spark ramp out occurs before fuel cut. Raising the values should eliminate the ramp out.
    If your Cal doesn't appear in the list above and you want to test please email support along with your .hpt file.
    Chris...
    I count sheep in hex...
    Houston, TX
    349
    Awesome, I'll DL and try later this evening. Thanks Chris!
    2.4L Twin Cam Cavalier Z24 | T3 Super 60 @ 9 PSI | FMIC | TurboXS RFL | Greddy Profec B Spec II | Custom HO Intake Manifold | 2.5" Charge Pipes | 2.5" Downpipe | HP Tuners | 5 Speed Swap | Team Green LSD | SPEC Stage 3 Clutch | Fidanza Short Shifter | Prothane Control Arm Bushings | Carbon Fiber Hood
    Houston, TX
    349
    Ok Chris, couple questions here...
    There are 4 new boxes that I see
    RPM - Drive (65535) RPM
    RPM - P/N (4000) RPM
    VSS - Reverse (26) MPH
    VSS - Not Rev (106) MPH
    What is the RPM - Drive and RPM - P/N mean exactly? And why is RPM - Drive set to 65535 RPM?
    Apr 2006
    Berkley, Michigan
    32
    Didn't work with CALID 12578485. I can see the new options just fine. I changed RPM - Drive to 7000rpm, P/N to 7000rpm, and Not Rev to 150mph.
    Here's a log of my lunch run up and down the freeway:
    Attachment 731
    I didn't get a chance to test out the vss spark limiter.
    Mar 2006
    Maryland
    96
    p/n = park/neutral
    2005 LS6 CTS-V
    2010 LP9 SRX AWD 2.8T
    SOLD: 2006 Cadillac SRX AWD V6 A5
    SOLD: 2005 Cobalt SS/SC Arrival Blue
    Houston, TX
    349
    Quote Originally Posted by zinner
    p/n = park/neutral
    Yeah, I'm a little brighter than that, I'm wondering what those numbers referred to exactly.
    they are spark ramp out points to ramp out the spark before the limiters hit, i guess to make the limiter a bit more friendly. Now ti seems there are yet more limits
    I'll find them, it's just a pain that it doesn't seem to be calibrated for most vehicles so we didn't see this one prior to release.
    Chris...
    Apr 2006
    Berkley, Michigan
    32
    Thanks for the update Chris.
    Also, why isn't my Injector duty % working with the scanner? I'm able to see it just fine on my car with a different type of obd2 scanner. Just curious.
    you have to be logging RPM and injector PW for the duty cycle to work. It is calculated not directly read from the PCM.
    Chris...
    May 2006
    Victoria BC Canada
    17
    /me starts begging chris for the update to be applied to his calid!
    Quote Originally Posted by Mr. Pute
    A specific Duty Cycle PID is actually NOT transmitted at all within the GM data stream. If available, it's totally a tool calculated PID using injector base pulse width and engine speed using the standard formula:
    RPM*BPW/1200
    HTH
    WOT
    May 2006
    Victoria BC Canada
    17
    /me starts humpin chris's leg... pleeeeeeeeeeeeeeeeeeeaaase can I get an update for my calid!
    Apr 2006
    Berkley, Michigan
    32
    Any more word on this actually working?!?!
    Id say it is I used to notice an instant change of getting richer at 6500 and beyond, now its leaner, like the rest of the powerband seems to follow the rest of the curve, as for power numbers i dont know i dont have a dyno with or without
    Apr 2006
    Berkley, Michigan
    32
    Chris/Keith,
    Anytime you want to comment on this PLEASE, feel free...
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,279
    what would you like them to comment on? Is there something still not working I guess?
    Apr 2006
    Berkley, Michigan
    32
    Quote Originally Posted by foff667
    I posted this a month ago:
    Attachment 731
    Just like I did a month ago, I'm still having limit issues. Nothing has changed even though the Beta 2.1.11 file keeps getting bigger. I'd like to hear an update from the head honchos to make sure they haven't abandoned us.
    Oh and my speed limiter is producing the same results.
    waiting for test results to come back
    Mar 2006
    Detroit MI
    68
    ANy news for VCM OS ID: 9351308 ?
    Quote Originally Posted by mpprotomec
    email me chris@ and i'll send you config to scan with to help with testing if you don;t mind.
    Chris...
