So I've been doing some messing with these tables, particularly the boost adder and its coefficient. I can't see any differences in main timing during logging. I've tried quite a few combos, and it never seems to stray away from the base (transient) table. I've also watched under cold start conditions for the ECT adder to add in its timing, but nothing there either. I'm trying to use the boost adder table to pull timing under afc conditions, without having to hack at my main SOI table. (As an aside, all my main SOI tables are set identical.)
Also, on a separate note, even after upgrading to the latest version of HP, the pilot SOI in my logs still has a 20* offset. So say I'm commanding a pilot shot 5* ahead of main , and my main shot is timed at 0* in my file, when I log, pilot says 25*. No matter where I look in my logs (both stock file or modified), if I take into account that pilot references from TDC when logging, and I subtract 20*, it's then exactly what my pilot tables are calling for.
Thoughts?
