Results 1 to 16 of 16
Thread: Proper way to flash tune on c7?
    May 2016
    20
    Every time I try and flash my 15 C7, it will run like crap, throw codes, and die. I have to get the car to fire up (dies most of the time) and delete the codes 20-30 times before they officially clear and the idle smooths back out. Everything is ok once the codes finally clear.
    Aug 2009
    Calibrating
    3,372
    Push start button one time... write calibration...when finished tap the start button 2x real quick and open door, shut door and hear 2 quick honks... then push start button again then you can press the brake and a start engine.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    May 2016
    20
    Thanks! I will try that next time. I thought I was opening the door to reset everything, but maybe I did with the key still on.
    I'm not exactly sure what codes it was throwing, but I think it said something about the key.
    Mar 2010
    Texas Hill Country
    3,299
    I just turn push the start button 6 times (on/off 3 times) then it will start fine.
    Advanced Tuner yonson's Avatar
    Nov 2007
    MiSSiSSiPPi
    234
    Quote Originally Posted by Higgs Boson View Post
    I do this, then open and close the door with the key off on every vehicle after a flash.
    Mar 2010
    Texas Hill Country
    3,299
    I think I usually flash with the door open already. :-)
    May 2016
    20
    I've tried all the suggestions and it still doing the same. Runs like crap. Throws p0697, p06a3, and p16f3
    May 2016
    20
    I saw a post a few years ago about someone having trouble like this and said it could be melted o2 wires??? I have had some melted wires, but thought they were fixed
    Hold the start button down for six seconds to enter full run mode. Do NOT touch the brake or start the car. Flash the vehicle then hit the button to turn it off. Wait five seconds then hit the start button one time (do not start). Start logging and reset trims with the VCM tools. Start vehicle and let idle to normal temp before capturing a usable log. Do not throttle the car while warming. Drive and log as necessary.
    4
    Was this ever resolved?
    May 2008
    44
    i also hit start button 6-8 times...
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Ive done several hundred gen 5 ecms, never had this, however today, it happened, same codes as mentioned above, and running on 4 cylinders. Only cure was reading and clearing codes while it was running. No combination of ignition cycles or writing would prevent it. Just had to clear codes continuosly until it corrected itself. Sometimes 1 time, sometimes 10 times, once had to do about 30 times. Frustrating
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Dec 2013
    Slidell, La.
    1,015
    Ok, so this is 100% a software bug
    doing another gen v and same thing, roll back from 4.9x to 4.8, and it doesnt do it.
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    May 2022
    This sucks ... nothing works. Downloading latest beta.
    This is officially dumb. New beta. Clear codes 30 times while running.
    Opening doors, pressing button, etc does nothing.
    Aug 2009
    Calibrating
    3,372
    What are you running into???
    14 Gen 5 Viper
