Don't know if I should post this here or in the transmission section. What we have is a 2015 Cadillac Escalade 6.2 DI/6lXXE trans. Stock trans with the drive train not sure if its an 80 or 90e. Swapped drivetrain into a 2000 Silverado with Speartech harness and Cadillac floor shifter with TUTD buttons. Problem is just trying to get the TUTD shifting to work properly.
Tried few different shift settings even copying everything over from 2014 6speed C7 with no prevail. Enabled TUTD option. With it set on Serial there was no change at all since we aren't using a BCM. Changed to Hard wired with range selector D4 and can hear transmission solenoid click and change from 1-2 but drops back down to 1 instantly. Stock shift speed settings for original tune is 318mph upshift and 317mph down shift with. Changed all to Zero like the C7 and still no change. Swapped it to Different shift pattern from X to Y pattern but still does the same just downshifts back to 1st. Regular D shifter selection shows D6 mode and Manual mode shows D4. It tries to shift when hitting upshift but shifts right back down sitting still or driving.
Maybe someone can shed some light on the subject.
