Results 1 to 6 of 6
Thread: Base Fuel Table
    Feb 2015
    Indianapolis
    36
    Base Fuel Table
    I always have wondered why the base fuel table has values that are either lambda=1, or lambda=.86 (or .82....whatever you WOT set to), but there is no transition. I know the PCM will interpolate to some degree, but I would think the table would be more precise if it had lambda=1 in the upper left section of the table and lambda=.84 in the lower right section, but also have transition lambda numbers in the middle part of the table that would be lambda= .90, .95, etc. so there was a smooth transition from idle to WOT.
    Nov 2009
    All Around
    3,149
    you can create that transition, also openloop by tps
    Apr 2005
    Sugar Land, TX
    1,198
    I think Sultan is referring to this table. My stock table is 90% all the way down.
    Nov 2009
    All Around
    3,149
    i would bring it down to like 50%
    Advanced Tuner 15PSI's Avatar
    Feb 2016
    East Coast Somewhere
    458
    Another Enrichment Pedal Example
    The enrichment pedal from my blower car. I drive this car daily with no issues.
    2012 Mustang GT with S/C
    4Runner with S/C
    Turbo/NOS Hayabusa - 320RWHP
    Feb 2015
    Indianapolis
    36
    Quote Originally Posted by 15PSI View Post
    My 2005 Mustag GT 4.6 3v does not show the same layout in the FUEL\OPEN&CLOSED LOOP. Doesn't look like there is a Pedal Enrichment option back in 2005. I'll try blending the BASE fuel table and see what the scanner/wideband shows.
