Hello all,
this is my first post and I appreciate all the information in here, I am very much an noob regarding some of the tuning tech in here. Im hoping you can help so I dont seek a "locked" tune for my car as I have invested in the pro vcm.
I have a
13 Coyote with a
2.8 kenne bell mammoth
168mm tb
long tubes full exhaust
oil pump gears/crank gear
return fore innovations system
id1000s.
the car runs mid 10s in tucson 3000 ft track on about 10 psi,
I have the WOT tune pretty close but running into HUGE stft adjustments and LTFT adjustments. Im having a stalling issue under DECEL and if i hardly accel and let off...
I was hoping you guys can look at my data log and guide me on how to fix this. I have played with the idle and cant seem to get it right.
Any help is appreciate and sorry if this is a redundant post.
the most KB tunes need to adjust the MAF error.
did you set the "transport delay" for the longtubes?
did you installed the air straitener from KB. the MAF sensor runs much more better after installing.
if set the MAF correct, the KB tunes runs MAF error near zero in all conditions.
