I had HUGE problem with my last GM 1.4 Turbo engine stand alone swap. The MAF was kept in the same general location, that is it was just after the air cleaner, and before the turbo inlet. It was mounted in a 2.75" tube as recommended by some experts. It always read way high. I took someones suggestion and zeroed out the MAF settings and ran the engine in Speed Density mode. It runs quite satisfactorily, and the customer was satisfied.
Now I'm about to do another stand alone swap and will try an experiment to keep the MAF reading correctly.
This time I'm getting the air cleaner box as part of the "lift out" package. (2014 Trax).The plan is the attach my Shop Vac to the tube that would normally attach to the Turbo inlet. run the Shop Vac and record the MAF reading.
Then after the swap is complete verify the MAF has the same reading as original. This may require changing tube size, but I'm guessing the reading needs to be the same as OEM.
Any one tried this?
How wrong could it be?
Sprinto7
