Hi Guys:
This is my FIRST and ONLY tune. I took this project on to learn; once I get through this one tune I'll have made it! Car - 09 Vette, stock except for an A&A Si-Trim (small blower) kit. I am ready to tackle my first tune issue. It's the low end up to about 2500 rpm, so nothing really to do with boost.
I've had the issue since shortly after kit install. First thing I did was ensure everything was good mechanically. There are no vacuum leaks. I am pulling 17" vac at 650 idle on a warm engine and at 2500' altitude. Fuel pressure at idle is 62lbs via gauge off the fuel rail.
My fuel trims (LTFTs) from idle up to about 2500 rpm are off the map correcting for lean. If I am cruising around town, stop/go driving, nothing above 3K rpm, LTFTs drift higher and higher until I hit MIL 171/174. So, I need some help/advice, where to begin getting more fuel in this range; or. a method to get LTFTs back toward zeros. Once I start running aggressively above 3K rpm, LTFTs start correcting and go back down to +12% and into single digits above 4K. These too are still too high, but I am trying to focus one place at a time.
I was out today, running stop/go and started a short 2 min DL from a stoplight (idle) through 4th gear. I've attached my tune as well. Thanks for your help guys.
