Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 68
Thread: Focus ST Torque Limits
  1. #41
    Quote Originally Posted by kris5597 View Post
    Which desired load are you speaking of that is targeting 2.2? My LSPI reduction or Maximum load under speed density?
    Kris
    Just based on your log. Nothing to do with your tune. Your log shows desired air load is 2.2. Your actual is 2.2. Therefore its operating as you're commanding it. If you want more boost you'll need more load.
  2. #42
    May 2015
    427
    Sorry, I was confused. You said my desired air load is 2.2 and the actual is 2.2, where are you seeing 2.2? I am seeing 2.3?
    Kris
  3. #43
    Kris
    Here for example:
    So what I'm saying is the TIP Desired in that case (70 in.Hg) derives from this desired load. Your throttle is closed off a little in this case because your desired TIP is lower than actual, so the throttle has to restrict airflow to prevent from flowing more load than you desired.
    You need to raise this load to get your TIP Desired to raise with it. This is because the desired load becomes a desired air mass, which goes through the VE equations to give desired pressure. Hopefully I'm making sense.
  4. #44
    Quote Originally Posted by Bugasu View Post
    -- Snip --
    Bugasu I would gladly pay if you wrote a guide/book on tuning these ecoboost motors. I've already stated saving some of your posts as PDF's I keep in my HPTuners folder.
    2016 Ford Explorer Sport - 3.5L EcoBoost
    2006 Ford F150 Lariat - 5.4L 3V (315,000 miles )
  5. #45
    May 2015
    427
    Bugasu, does the throttle always regulate boost at WOT with torque limiters removed or refined? Does the throttle ever stay open at WOT and the waste gate regulate boost?
  6. #46
    Quote Originally Posted by Trent_Petersen View Post
    I appreciate the sentiment. Making a book though is a lot of work, and I don't know if I currently have the time to do so.
    The throttle regulates airflow. It is controlled directly from desired airmass. The factory tune often uses more TIP than is needed to achieve a desired airflow or rides it really close, so the throttle in this case regulates boost.
    In order to keep the throttle open entirely, you'd want your desired load to always be out of reach of the actual load you can hit. Look at your log at the high RPMs for an example, desired load stays up, but actual load just simply can't reach it.
    A way you can do this is to have your desired load request a TIP that would be quite high (say 25psig), but you only want say 22psig. You can set your TIP Desired Max to be 23psig in this case, actuate your wastegate to only hit 22psig, and the throttle should stay open because you're never going to hit your max as well. Take a look at Cobb's Ecoboost tuning guide for this.
    I will add, you may not always want to do this. For example, on a car like mine with an upgraded turbocharger with much higher inertia, I actually allow the throttle to close down low and limit my airflow and let the turbo overshoot a little bit. This gives you a faster response than controlling the wastegate to just hit a set boost. Of course, you need to have headroom, and remember that power generated by the turbine at these higher airflows typically also comes with higher turbine inlet pressure, which means reduced VE and thus overall efficiency. Trade-offs for everything.
  7. #47
    May 2015
    427
    Ah okay, makes perfect sense. IMO the boost regulated by throttle is genius and as you stated, more responsive. I don't feel there is much benefit by changing it over. I feel more comfortable allowing the ecu to use the throttle to regulate boost based on load than trusting the waste gate to do its job as the primary source of boost regulation. I've seen many other vehicles suffer from overboost issues due to undersized or overworked wastegates. I just wanted your opinion on the matter.
    I have found load limiters elsewhere that were not allowing me to hit my target boost of 22 psi. I have since adjusted them and I am comfortably hitting 21.9psi. I'll take that. Car pulls hard and strong. Next is e30.
  8. #48
    Senior Tuner metroplex's Avatar
    Apr 2013
    Detroit, MI
    1,077
    I used the Max Desired TIP pressure to limit boost, I'd set it to the absolute boost level desired. For the Max TIP and Min TIP tables, I didn't really see any correlation with limiting boost. For example I set the max TIP tables to about 17 psi but can hit 18 psi if the Max Desired TIP Pressure was set to 32.5 psi
  9. #49
    May 2015
    427
    My issue was what I believe were three tables that play a role in torque calculation. I'll mess with them more to see if I can get the car to hit the TIP max desired limit.
  10. #50
    May 2015
    427
    Update, the car now rides between the LSPI max load I have set as well as a matched TIP Max desired. No more insufficient fuel and no more hidden torque limiters. I am running 22-22.5psi of boost hitting max load of 2.5 and quite a lot of torque.
  11. #51
    Apr 2013
    Detroit, MI
    1,077
    What changes did you make?
  12. #52
    May 2015
    427
    I raised torque calculation, torque inverse, and IPC tables to allow more torque than I know the car will make. I now run the car off the LSPI tables and TIP Max Desired. I put E30 in it last night. The car is not adding timing as fast as I expected initially, that I am used to compared to coyotes. I will be increasing the knock advance rate limit to see if I can get it to add timing faster.
    Kris
  13. #53
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by metroplex View Post
    What table # is the Lambda Torque Adjuster table in the Focus ST? Where is it found?
    I've got this table coded, what vehicle do you want it added to?
    Eric Brooks
    HP Tuners, LLC
  14. #54
    Apr 2013
    Detroit, MI
    1,077
    2014 Ford Taurus SHO
  15. #55
    Jan 2013
    Hawaii
    2,101
    Under fuel sys > fuel pump you have fuel pressure that you can increase some. Seems like you found a better way around the fuel flow tho.
    You are using the low speed pre ignition tables which the eco boost engines have a known serious problem with so be careful how far you take that in the lower RPMs with out considering upgrading your engine internals.
  16. #56
    Apr 2013
    Detroit, MI
    1,077
    What's the serious problem with the LSPI tables? It seems a lot of tuners just increased those values across the board.
  17. #57
    Jan 2013
    Hawaii
    2,101
    nothing wrong with changing them. Its necessary in order to increase boost and performance. I was just saying you do not want Low speed preignition. The ECO boost motors are prone to it being turbo charged and direct injected. So you dont want to be pushing it in the lower RPMS too much.
  18. #58
    Apr 2013
    Detroit, MI
    1,077
    So we don't want to lug the engines (high load at low RPMs)?
  19. #59
    Exactly
  20. #60
    Jan 2013
    Hawaii
    2,101
    tell that to the owner of the car you just tuned and it blew up.
