Results 1 to 16 of 16
Thread: 2017 Silverado 5.3
    Mar 2008
    211
    2017 Silverado 5.3
    Customer says he cannot feel anything with the changes done on his vehicle.
    1st attachment is the changed file...basically leaned out AFR to 12.4 and adding in some timing as he uses 93 octane. The 2nd file is stock file. All my previous truck customers have been happy and felt the differences with these basic changes, this is my 1st 2017 and seems very similar to the other trucks. Any suggestions to get some umph out of this tune would be appreciated.
    2002 6.6 TR6060 ZO6 (520Whp)
    2014 Audi S7 (730whp)
    Tuner in Training thewhip's Avatar
    Mar 2015
    USA
    17
    Try lowering PE Delay, stock is 5000rpm. Maybe some trans tweaks for more aggressive downshifting.
    Also you changed IAT spark base between 158-194, put that back to stock.
    Timing is very aggressive, have you made sure its not knocking? Your past MBT.
    Mar 2008
    211
    Found 1 degree of knock. Going to pull back on the IAT spark. Thanks for your suggestion on the trans tweaking.
    Feb 2013
    14
    cant tweak tran, its a 2017 model
    Tuning Addict
    Jan 2015
    6,802
    You've got customers happy with these changes? Looks like you just changed a couple of things and that was it...
    ~Greg Huggins~
    Mar 2008
    211
    I call them BASE tunes $150. Yep and they keep referring customers to me.
    Mar 2008
    211
    Quote Originally Posted by tooslow View Post
    I emailed support to verify.
    I have access to the trans tables for 2017. Are you sure?
    HPT Employee Engineer@HPT's Avatar
    Jan 2015
    fecadefa
    615
    Quote Originally Posted by maxgee View Post
    Some 2017 vehicles use the T87A modules and others use the older T43 & T76. Only the T87A is not supported, the others are.
    Aug 2016
    23
    how do i find my module number, and when will the other modules be covered?
    Quote Originally Posted by Engineer@HPT View Post
    Has there been any progress tuning 2017 T87a trans controllers?
    Chuck CoW
    Chuck Mosello - CORVETTE DOCTOR
    Corvettes of Westchester
    www.CORVETTES-OF-WESTCHESTER.com
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Chuck CoW View Post
    Chuck CoW
    http://www.hptuners.com/forum/showth...ison-Supported!
    Jaime
    Potential Tuner Djbillyguns's Avatar
    Aug 2020
    Hershey Pa
    3
    I just got my 2017 silverado tuned. And the only difference I feel is no more v4 mode. And in park rev limiter is raised to 6000 and not 4000. The other thing I noticed. Is I can not break torque. With track off and stable track off. And how do u keep the stable track off after 35mph. It come back on.
    Oct 2018
    44
    Quote Originally Posted by Djbillyguns View Post
    Stabilitrak can't be turned off in the tune. Its controlled by the bcm. The only option that I know of is to unplug the front left wheel speed sensor wire. I've seen someone makes a plug and play switch that Ts into that plug and allows you to disable it whenever you need it to.
    You probably still have brake torque management enabled in the tune.
    2016 Silverado CCSB L83/6l80e
    TSP cam 218/226, .635"/.635", 113 LSA 10% FL
    TSP LT headers
    Circle D Billet converter
    Apr 2014
    North Dakota
    64
    I put a switch on the power wire to the steering wheel position sensor to kill stabilitrac. Its located under the dash on the steering column. I still have to turn off traction control separately, but everything stays off this way.
    2014 Silverado L83 | Knockoff S369 Turbo | LT1 Fuel Pump and Injectors | MAST L84 Port Intake | MS3Pro Secondary Fuel Computer
    Aug 2020
    Hershey Pa
    3
    Quote Originally Posted by MORLOK View Post
    Any pics for reference. And does any one know how to get the downshift in tow mode to act the same as it did before the tune. I took the lock out of 2345 and left it in 6th. Do u think that has something to do with it.
    Aug 2020
    Hershey Pa
    3
    one other thing. Once u rev the truck up in park. Or neutral, the rpms almost feel like they get stuck it takes then long for them to drop. Any one know the fix. Or is there a tune for that too. Im new to all this.
