looks like i'm to dumb to set it properly and need step-by-step manual how to.
so i have 2000 LS1 Camaro engine in SD mode - MAF less.
Ignition map is RPMxCylinder Airmass (g) in Editior, how to set scanner to log it propperly?
No matter what i do scanner only reads top row (0,08) in but RPM reads good.
I tried use stock parameters (bone stock install), user defined found on board but no luck.
Or maybe someone can share configs, layouts etc. ready to do it for 3.4 scanner.
best regards
