Results 1 to 5 of 5
Thread: lm2 wideband getting graph to read error
    Aug 2016
    15
    So how can i get the graph to read error right, i got my channel reading right using transform and tried creating a math parameter by copying what they had for EQ ratio error and putting the transform equation at the end... no luck Any help? lm2 serial hookup
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Post log
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    You aren't logging commanded air-fuel ratio. Add that to the list of channels you're logging, then AFR error should work.
    It has to have something to compare wideband AFR to in order to calculate the error %. If you aren't logging commanded air-fuel ratio then there's no way for it to do that math..
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Aug 2016
    15
    thanks!!!!!!!!!!!!!!!!!!! ill give it a whirl
