Results 1 to 3 of 3
Thread: 2012 6L80e Back-Date With 2009 T43?
    Nov 2016
    35
    Hi all. Have done some deep diving, and mostly come up with the same story, but there was one exception, so now my confidence is dented.
    I have a good buy lined up on a 2012 6L80e 4x4 trans, but I want to adapt it into my 2009 Colorado (factory V8/E67). I understand there is a communication protocol change GM made in 2010/11 with the T43, so there is strong advice to simply match the year, therefore I should be targeting a 2009 6L80e and be done with it. I can get the 2012 6L80e for $650, and a used 2009 T43 for $100. A 2009 6L80e is otherwise $1000 and up.
    I did find one article saying there was a corresponding change made to the valve body at the same time, so now I am confused if you can simply put a 2009 T43 into a 2012 6L80e, or not. I think so, but now not certain.
    I do have full access to GM MDI tools and subscription, if I am able to back-date the included 2012 T43 to 2009 operating system, but I think even with the proper GM tool this is unable to be done? Or, is that only the case with aftermarket re-flash programs such a EFI-L and HPT?
    End question becomes, will a 2009 T43 fit and work in a 2012 6L80e?
    Thank you in advance. If I missed a similar article, apology.
    Nov 2016
    35
    Another possibility would be to uprate my 2009 Colorado E67 to 2012 operating system, and then not have to change anything regarding the T43? Or am I on the wrong path entirely with that?
    Jan 2004
    Perth - Western Australia
    276
    I've read that changing the vin on the ecu to match the year on the t43 can fix any issues. a member on the efi forum who does retro kit installs tested it out with a car that wouldnt get reverse. he was able to use 07/08 e38 with 2012 tcm's.
