Just curious as to what some of you think. Also, the commanded throttle position for PE isn't actually the TPS that you see in the scanner. I had to set my TPS enable to 5% because I was having a issue with it not going/staying in PE when I was commanding it to. Right now I have my PE set to 2750 and 100KPA. Random question
1. If you have your MAF set to take over VVE at 2750, do you need to tune the VE all the way to 3500-4000?
2. When would you want to have the MAF take over on a boosted vehicle? Is there really a particular rpm you would want it to come in?
