Getting this on 4th and above gear on mt. Any ideas what may cause this?
May be that rear end is not stock, but i tried few settings but no luck
Eastern and Central Europe American Muscle and Harley-Davidson tuning
www.hd-customs.pl
http://www.facebook.com/hdcustomspl
OK, so i fugured out the problem, as i thought it was gearing. So setting gears via VCM scanner does nothing, BCM gets this, but speed is not corrected after that. Must be done in tune and in BCM.
Now it works.
www.hd-customs.pl
Thats exactly the same problem I had when I tried to change the diameter of my tires. I put everything back to stock else I was getting transfer case torque limit. Haven't tried again with the latest updates
I am also curious about this torque limit. I saw it briefly at drag strip run a few months ago. I'll have to go look back at the log but I believed it happened during some wheel hop. Car is a 2016 PP M6 with just CAI and cat back.
It may happen also with different tire size.
www.hd-customs.pl
No gearing or tire size has been changed on my car. Only saw the source for a quick moment but haven't seen it since. Just thought it was odd.
