Originally Posted by
VicC7
Interesting, Ok so what does the ECM use as reference then, pulse width or injection timing. Because I work with the start of injection on this car.
first at 10 degrees obtained an AFR 12.6 without met. Then Added meth until the car was reading 11.0 then added timing. And finally reduced the PE just enough to increase the fuel rail pressure to my like which ended in 11.5 AFR. Is there any injection time in ms that I should not exceed? This cars use narrowband o2 thus definitively is not from actual AFR reading.
Regards
