I have a file I wrote and I'm trying to copy some of the tables from one to another. it wont let me do it anyone know why? also is there a faster way to copy a complete tune onto another tune?
Open file you want changed
Open compare file you want to copy from (compare-->open compare file)
hit ctrl + 5 to bring up list of differences between those two files
Right click somewhere in that window, hit copy over all differences and it will copy over everything it can
Keep in mind if for instance tables don't line up from one tune to the other then it won't copy them over (i.e. maybe one has a MAF high and a MAF low table vs. the other that just has one big MAF table.. those wouldn't get copied over)
And you're done
Or you can go through table by table, go to differences view (ctrl+4) and set each table to 0 and that'll make your new file match the "compare" file you're wanting to copy
since VCM 3.4 I can't use the comparitation function in the VCM editor. the values cannot set above the max. value in tables and some tables will not accept the hidden parameters full.
and yes, the editor ask me if I will overwrite the max values and I confirm it.
but its not possible to use the comparisation copy function.
did it allready. weeks ago! ticket #61547
its hard, that that fuction is unusable for long time. maybe you can push it more??
I still wait for bug fixing! longer than 6 weeks. with 3.3 VCM editor it works all the time. Since 3.4 release, every day the same shit. That the compare function not correct work, its possible to do with hand working. But the most worst thing is, its not possible to set the limits higher in tables than the software like it.
is that so heavy to solve?
Henry
