Results 1 to 10 of 10
Thread: Buying new injectors
    Jun 2016
    29
    I know what size injectors I need. Who knows what all data do I need for tuning them?
    13,578
    For what?
    What injectors?
    What company?
    So much information you aren't telling us. Buy injectors will known good data from companies that sell quality injectors.
    Jun 2016
    29
    It's for my 99 Camaro with a 6.0 swap LSX intake, 227 235 cam, stock head. Looking at 36lb injectors. Was looking to see what I needed to tune them. And then I was going to look for who provided me with all the data I needed and with the high quality and reasonable price
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Pretty much all the injector companies will claim they have data these days. Whether it's actually anything more than a steamy pile of crap they made up or not is anyone's guess. ID's data is as real as it gets, and that's why they cost what they cost.
    You'll need flow rate, offset vs. vacuum/voltage and short pulse adder at least.
    Advanced Tuner 15PSI's Avatar
    Feb 2016
    East Coast Somewhere
    458
    Injector Dynamics are worth the price. If you are not convinced how much science Paul puts behind his brand, watch this: https://www.youtube.com/watch?v=_UZ6wYTjUpo
    2012 Mustang GT with S/C
    4Runner with S/C
    Turbo/NOS Hayabusa - 320RWHP
    Advanced Tuner Jabbott's Avatar
    Oct 2006
    Richmond
    223
    The ID injectors are too big for what you are looking for. But most all companies data is stolen from other data which doesnt work. Zip has 58lbs injectors with real data that Greg Banished helped out with. However in that you need 36's you can use a stock GM injector. I believe they were the factory injector, GM has a white bosch that is 36lbs. I forget what the factory application was for it, but you need to find out and then use that data.
    Too many unfinished projects
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    ID's would work perfectly fine IMO but if there's a lower cost factory GM injector (which should have accurate data..) available then might as well go that route instead to save some cash.
    Oct 2006
    Richmond
    223
    Why would you use such a large injector when a small one is needed. You get too large and it will not idle well no matter how good the data is.
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    I'm not saying it's the best option, I'm saying they'll work perfectly fine. I've ran ID1700's on a stock LS3 and it idled perfectly fine. And is good for 1000+ on E85
    Australia
    1,987
    i had bosch 2200cc working fine at idle on a 3x scaled tune even got down to 0.6 ms IPW at idle no issues, good injector good data shouldn't have any issues, i wouldn't put that on a n/a motor but it can work
