Results 1 to 4 of 4
Thread: Incorrect Fuel Boiling Time Value Scale
    Oct 2015
    19
    I think my P59 ECU is setup with an incorrect scaling formula. The values are not within the range set (0-20) and therefore I cannot change them without getting a parameter out of range message. And because of this I'm not sure that it is even changing the correct values in the tune.
    OS ID 12579405 -> 1253050
    Here is the table
    [ECM] 12280 - Fuel Boiling Time vs. Coolant vs. MAP:
    Jul 2006
    Lady Lake Fl
    50
    I'm having the same problem. 03 Silverado
    95 Maro LS1 Swap
    03 Z-71 Silveraldo, Pewter ECSB
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Email support a copy of the tune and exactly how to reproduce the error
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Jan 2014
    Australia
    1,981
    might just need support to adjust it i had a table once that would warn u when changed to anything even back to stock values, support ended up fixing it in an update
