Results 1 to 14 of 14
Thread: 6l80e fast learn procedure problem
    Feb 2013
    glennville ga
    168
    I have read the stickys and researched like crazy. My issue is everytime I try and get it to do a fast relearn the scanner status says Temp Low. Ive logged trans temp in Celsius like the sticky say to and can only get trans temp up to around 79*c which is around 170*F. Stickys said mandatory of 70*+C. What could be my issue? Do I need to go for a longer drive or something?
    Also, I didn't hit the reset and presets before trying this. Maybe that would help? whats the mandatory temp to try and get the fast learn to activate?
    2000 silverado rcsb lq4/4l80e. Custom s480 turbo setup. 93oct meth injected. SD Tuned by me.
    2007 tbss ls2/4l80e. Nitrous!!! MAF Only Tuned by me.
    Feb 2013
    glennville ga
    168
    has anyone else had the temp low problem? what should I do to try and get trans hotter? trans shifts like shit right now. Hopin will help.
    13,557
    I never got it to work myself even with transmission temps over 170 degree's.
    Anytime I do changes I've just done the trans preset/reset and been fine.
    Jan 2008
    Toopekid, Ks
    74
    Try it with the park brake set.
    2017 Sierra Denali 6.2
    1986 K10 L86/8L90/NP205
    Feb 2013
    glennville ga
    168
    well I would but its in a swapped c10. I didn't give the preset/reset a try yet. ill try it and report back.
    Jan 2008
    Toopekid, Ks
    74
    Yeah, didn't know if you incorporated a bcm or not.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    IF your not up to temp, it will not allow, had this issue on tech 2's early on. It has to be above temperature before clicking the button. I believe it internally times out before it will allow it. If you wait till its about 10* above temp, then click the button, it works everytime for me
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Feb 2013
    glennville ga
    168
    shit I drove it around for about 15-20 miles and it still wouldn't hotter than a 170*. I figured that would have been plenty for it to activate. I gave up on it. Fans run full time on this truck so I don't think trans is going to get any hotter. Ill try a longer drive and see if I can get up around 180*.
    May 2015
    6
    pretty easy for me did a couple of WOT runs back to back got it up but summer time here gets like 90+ so its pretty easy to heat up lol
    Tuner in Training Longslyde's Avatar
    Jan 2012
    St. Cloud, Minnesota
    38
    Easiest to place the vehicle in drive, hold foot solid on the brake, and throttle lightly and hold it there until your temp reading gets above 170. You're not slipping the tranny, but the converter will heat the fluid...
    2017 GMC Sierra Crew Cab
    Forged 6.2L Flex Fuel Tuned
    Twin Turbo 13 PSI
    8L90E Transmission
    3.23 Gears
    Yes, it runs on E85 too and LOVES it! ;D
    Feb 2013
    glennville ga
    168
    I drove around and had it over 170 still wouldn't start. Said temp lo. Could it be with this setup being swapped into an older platform that it may not have all the needed features for it to work right? like being on the brakes. How would it know? only thing brakes are doing is unlocking converter.
    Mar 2015
    Dallas, TX
    39
    Your problem may come because the modules are not receiving the brake signal, you're going to have to ing?nate them with someone who helps you install a system that recognizes the signal of the brake pedal
    Feb 2013
    glennville ga
    168
    got trans shifting a whole lot better. I used blue cats trans calculator. Shifts are near perfect. ALso, noticed for WOT shift points the Seed settings need to be lower than say a normal trans like 4l80e. I dropped the speed and shifts dead on the money at wot. Thanks guys.
    Advanced Tuner lt1z350's Avatar
    Mar 2014
    Dandridge, TN
    560
    Seems the shift points and learn are critical on this thing. I did a 6l80e swap to my 07 tahoe and with out a quick learn it’s flairing on light throttle part throttle is decent I’m afraid to give it hell not shifting right. It’s built ratbestos red and kolenes and running a zl1 torque converter. This early lock up is terrible at low speed locks so hard takes a lot of throttle to get it out so really needs lots of fine tuning I can tell. It doesn’t like the stock program with this tc. I’m hoping a quick learn will help but same issue trans will not get over 140 degrees so far. I have also got a few random tc on in reverse and first that kills the motor. I really hope it’s a control issue as not wanting to pull this beast again.
    First 9 second 6th gen lt4 zl1 stock blower SHC SBE boost only.
    2013 cadillac ats 2.0t Big turbo-gone
    2007 tahoe 5.3 lsa blower on 14 lbs boost 6l80e swap 2009 os
    2017 zl1 a10 big gulp/2 inch headers/ 9.55 lower/ e85/bigger hx /103mm tb / Synergy trunk tank and underhood kit/methanol injection with torqbyte controller and prometh pump / Jokerz performance R&D ported stock blower/ lme cnc heads /GP tuning custom cam. So far 9.30@150
