I have an older Ford with a built GT500 engine swap and a 3.4 Whipple. The car starts and idles decent but struggles to rev past 3500rpm. What I`m noticing is that the engine will accelerate smoothly and then will drop into open loop and then it`s like it hits a wall. You can see in the datalog, as I bring up the RPM it immediately falls flat when open loop hits. I have tried a number of different things in the tune to prevent this from happening with no luck. The engine feels like it is getting loaded up and if I push it it,will actually build boost in neutral - something I have never seen. It acts like a car with plugged cats. It does not have cats. I spoke with a tech at Whipple and he was baffled. Apparently the base tune was written using SCT, not sure if this is why I can`t seem to get the tune to react how I want it to, if SCT maybe has a different strategy for open/closed loop that I can`t see. Would appreciate any input on this. I have attached the base tune and a datalog. The datalog is a little long but you can really see the issue around the middle. Thanks!
