Results 1 to 8 of 8
Thread: 2010 E38 2Bar Upgrade: Urban Throttle Mode
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    Just curious what this is. It's a new table, popped up with one of the HPT updates within the last month
    Airflow/Electronic Throttle/Misc
    ECM 13545 Urban Throttle Progression
    ZL1 Wheels/Tires
    Australia
    1,981
    ive noticed a couple little things pop in last few months, got the feeling it's a limited tps if u don't want the vehicle to be flogged when someone alse is driving, but havnt tested it to see
    Mar 2012
    Detroit, MI
    1,320
    that would be nice to have... who wants to be the first to try it??
    ZL1 Wheels/Tires
    Australia
    1,981
    yea and looks a little safer being a enable/disable so not stuffing with the pedal values, still a bit scared tho... also noticed a "Min RPM ref" in the adaptive idle page not too sure on its exact use but seems like it should be set to the same as your idle speed for a reference which may help with some idle issues if it wasnt adjustable before and u changed idle speed from factory
    Jan 2008
    242
    Please like to know what this table for,Urban Throttle?
    Mar 2008
    34
    bump
    Oct 2015
    Pulling that question up again - what is the Urban Throttle Mode for?
    Can be enebled and disabled but what does it cause?
    Apr 2007
    330
    Quote Originally Posted by LdkE View Post
    My guess is that its some kind of mode/algorithm that senses when you're in stop and go traffic and adjusts the pedal progression to probably try to make it less sensitive, so you don't get the head bobbing back and forth while constantly speeding up and slowly down when traffic is creeping along. My L9H file has it disabled so I enabled it but it hasn't seemed like its done anything.
