Thread: HS-CAN IDs 2007+
    May 2006
    Bowling Green, KY
    103
    HS-CAN IDs 2007+
    Has anyone on here bothered to decode the generally broadcast HS-CAN IDs? I am in the process and have about 1/2 of them done, but wondered if anyone else had already done it? I'm using it for a small monitoring device with a screen and feedback into the bus based on certain conditions.
    Any will help, as I am working from 0C9h all the way up to 77Fh (engine and 6 speed auto trans only, I don't care about any other modules).
    Mike
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,795
    Yes, I did. No, I won't share them because it made me want to slam my dick in a door, and it's for a proprietary Motec system. If you can bench test, it's not so bad, but depending on what application you're doing, it's going to get bad if you really want all the details like fuel related broadcasts. Plus, many vehicles are different. RPM and Throttle are in different addresses on a Camaro vs. Corvette even though both are E38.
    http://www.dsxtuning.com
    Just say no to bull s***.
    May 2006
    Bowling Green, KY
    103
    I understand that DSteck, I have only been at it for a couple of days and am about 1/2 way done. I am not decoding all 100 IDs on the bus, only the (approx) 20 main generic engine/trans ones. Out of curiosity, could you show me one (say 0C9) to see if it is the same as the truck? I have compared a 2008 and a 2015 and everything seems to be in the same place there. In 0C9h, I have found (from 0-7): bit status info, RPM, RPM, unknown, PPS, bit status, unknown, unknown.
    Obviously, I am working on the unknowns still. I only looked at the data for about 10 minutes at an idle on both vehicles, so I didn't grab that much yet. I will be getting the 2015 on the dyno tomorrow so I can get a little real information and spend a bit more time with it.
    Thanks,
    Mike
    Dec 2006
    Birmingham, Alabama
    122
    Quote Originally Posted by Mike@ADS View Post
    Thanks,
    Mike
    0C9 is the TACH. Byte 1 and Byte 2. both are multipliers. Byte 0 has something to do with idle or off idle.
